got a questions on recommendations for a case for odyssey7+ Wondering what everyone is using? I can get a hard case but then it adds bulk to my load.
There is also a port-brace - more for field use. I was wondering what others were using?
When you say a case, do you mean an equipment case for carrying the Odyssey7Q+ when not in use or do you mean one of the various accessory cages for when it is in use? If a transport case, do you want something in which you can ship it individually or do you want to protect it when inside a larger case? Give a little detail on how you'd like to use it and we can be of more help.
Convergent Design sells a case with custom foam insert to hold the Odyssey7Q+ along with accessories.
I guess I want it for several options. One option would be to use on set on stand and or camera. I just ordered the port brace for on set work. I have hard pelican cases for transport should that be required. I might just order the Convergent Design hard case. My shooting situations are never the same so I am need of options. I will see how that rain and dust cover case works. I am new to the 7Q+(with FS700) so I am learning as to what I need and it's operation. Figuring out S log exposure will be the next plan. I was asking just to see what others were doing - as I get good information fro these forums.
thank you Mitch for helping
[TABLE="class: MsoNormalTable, width: 382"]
[TR]
[TD] [FONT="]MO-ODYSSEYQ Rain and Dust Cover for Convergent Des[/FONT]
[/TD]
[/TR]
[TR]
[TD] [FONT="] [/FONT]
I also have the Portabrace rain jacket for both the 7q and the FS700. They are both a bit fiddly to put on especially if your using them at the same time. Also, If your 7q has a cage and battery plate makes it a little tougher but you can make it work...but again, takes a bit of patients. However, I'm mainly shooting doc work outdoors and they have both saved my bacon any number of times when the weather turned to #hit and I've been caught in some nasty stuff.
In transit...I also use PB hard shell cases for the 7q and camera.
If you want a nice hard case to transport the Odyssey7Q+ with its accessories then our case works well. But you would need to remove the Odyssey from the PortaBrace cover to place it in the case (that's pretty easy). If you want to store your Odyssey inside another case, I suggest a neoprene pouch designed for a tablet. If you have a battery plate and/or a cage or other accessories you wish to leave mounted on the Odyssey then you should plan on getting a larger pouch meant for 9-10" tablets. There are various models of these available for around $10 on Amazon.
Good information - today I will order the CD case and go to a tablet store and get a neoprene pouch - good idea. So I think I solved the protection issue.
thank you for helping
Larry
Also have rain jacket for FS700 and it is a bit of a pain to put on. I will see how the rain jacket is for 7Q - will also get the CD case today
thank you
When you go to buy the neoprene tablet case, make sure to take your Odyssey7Q+ with you. And have it kitted out with the items you intend to keep on it at all times, such as the battery plate, any cage if you're going to get one and possibly the SSDs.
I'm pretty well satisfied with CD's Nanuk 910. Nice and portable with just enough protection to keep it from getting banged around. I've had it over a year, holds up well.
Unexpected benefit is I can squeeze it into a backpack so I can carry it onto a plane with me.
