sodotoguwangus
A potentially stupid question, but . . .
About the rec lamp. In the menu, you can select FRONT, REAR, or BOTH.
How come when I select FRONT (for example) the record lamp always flashes regardless of whether or not I'm actually recording? I thought the lamp was only supposed to flash when recording. Mine flashes all the time. Same with the REAR and BOTH settings. They flash all the time.
Is this normal?
Also,
The BEEP SOUND option in the menu. I have mine set to ON, but my camera never beeps. Is it supposed to beep when you start recording? Or at some other time.
Thanks.
Is this normal?
Also,
Thanks.
