Ed Jeffersen
Vectorscope
I could see this as being correct but you are making some assumptions here which we can't really verify. We know the camera can encode 200Mbps. The question is, is getting from the 4K to 200Mbps more processor intensive than going from 4K to 100Mbps or going from HD to 200Mbps. To me it is perfectly plausible that compressing 4K Raw off the sensor to 100Mbps might be more processor intensive than going from 4K to 200Mbps. The smaller CODEC requires math to shove the same'ish video quality into less bandwidth (100 Mbps) which to me could possibly mean more complicated math and therefore more taxing on the processor. We don't really know if this is a limitation of the processor. It might be but unless you are on the Panasonic GH4 development team you can't really verify 100%
In terms of compression, 200 Mbps is less CPU intensive than 100 Mbps
...Assuming the SAME 100 Mbps image data is being stored at the 200 Mbps data rate, as I can't image storing 2x as much image data with a 200 Mbps video data stream is going to be less CPU intensive. So 200 Mbps with the SAME artifacts and macro-blocking as the 100 Mbps video stream would likely lower the CPU usage, but doubling the 100 Mbps image data being stored in the 200 Mbps video stream would logically require MORE CPU power. ( no "free lunch" when encoding more data )
If we double the bitrate we can double the bits for I-frames or double the number of I-frames, increasing quality with either the same CPU load or decreasing it.
In theory this sounds do-able, but is the hardware actually able to support processing and storing this extra data continuously without overheating ?
I think only Panasonic engineers are able to answer this question definitively.
FWIW, I doubt that Panasonic intentionally crippled the 4K ability of the GH4 in any way.
We have H.265 to look forward to in future cameras
1. please make it so aperture, iso, and shutterspeed don't stick to the C1, c2, c3 settings. It's annoying to have exposure dialed in on c1 and then switch to c2 (which I have set for slow motion) and then have to reset the aperture, iso, shutterspeed
