Real 1080p \ 23.97 Raw MXF file
CINE-HOBBYST
Can you please, any of you lucky guys with the AG-HVX200, give us some real 1080p In 24p (actually 23.97) in MXF format. Thank You in Advance.
Any 1080 clip is going to be stored in 60i, because that's how the codec works. It's exactly the same as how the DVX, SDX, SPX, and XL2 store 24p -- it's 23.976 progressive frames per second carried within a 1080i data stream.
So if you import a 1080i/24p clip into your editing program, you'll see that it has 3:2 pulldown applied. If you import a 1080i/24pa clip, you'll see it has 2:3:3:2 pulldown applied. You'd need a 24p-capable editing program that knows and understands 1080/24p pulldown and can reverse the pulldown in order to get at the pure 24p data sequence.
