Re: VIDEO AF - Sony A6000 / A5100 + Metabones EF Adapter?
Anyone tried using the EF Metabones with either the A6000 or A5100?
I was wondering how smooth and responsive the AF would be for video recording?
It's pathetic... but don't take my word for it, this is from the Metabones site:
Autofocus is supported, with the following known limitations.
  • Autofocus speed is very slow and inadequate for most moving subjects. The autofocus speed is unfit for professional use for sure, and it would disappoint most enthusiasts.
  • Only Canon-branded lenses introduced in or after 2006 are officially supported. Autofocus may be disabled for older Canon lenses and most third-party lenses, including most Sigma, Tamron and Tokina lenses and all Contax N lenses modified by Conurus.
  • On NEX camera bodies in camcorder form factor (e.g. FS series), autofocus may be available only in photo mode but not in movie capture mode.
  • Continuous AF is not supported.
  • DMF mode (direct manual focus) is not supported.
  • For non-camcorder camera bodies (e.g. NEX-7), during movie capture, if the subject moves to a different distance, half-press the shutter release button to re-activate autofocus and lock onto the subject again. Since autofocus speed is slow, there may be visible disruption in the resulting footage.
  • The first two autofocus attempts are used to calibrate the lens and as a result may not lock successfully on the target. Half-press the shutter release button again and autofocus will lock successfully.
  • Autofocus may have difficultly locking onto subjects which are very close to the nearest focusing distance of the lens.
  • Autofocus accuracy depends heavily on the working condition of the lens. Lenses with hidden problems which may not be apparent on Canon DSLRs will lead to inaccurate and unreliable autofocus on Sony NEX. Typical problems of this kind that we have seen include an unsmooth/erratic autofocus mechanism (e.g. getting stuck intermittently at a certain focusing distance), a faulty/worn-out distance encoder or other faulty/worn-out internal sensors.
Maybe the Lens Turbo works better, not sure... I gave up with solutions like this, already using lot of adapters for OM, Nikons, M42s.
Waiting for the A7s ii for a real FF :)
