ectobuilder
Re: [via EBAY]: ZCAM E2 + SMALLRIG CAGE // Used Like New!!!
EBAY LINK: https://www.ebay.ca/itm/123950542449
ZCAM E2 (4K 160fps) - Firmware 0.89
***THE BUYER IS 100% RESPONSIBLE FOR PAYING ALL DUTIES, TARIFFS & TAXES***
USED LIKE NEW - Used for one project. I couldn't rent one locally so I had to buy one. The project is completed so now it is time to sell. This is an excellent opportunity to save a few bucks on a like new incredible cinema camera.
WHAT IS INCLUDED:
1 x ZCAM E2 body
1 x Smallrig Cage
1 x Body Cap
1 x Power Cable
WHAT IS NOT INCLUDED:
- CFAST media is not included
- Batteries are not included (takes Sony L series)
- USB-C media not included
HIGHLIGHTS OF THE CAMERA:
- Up to 4K 160fps in 2.4:1 aspect ratio H.265 10-bit 4:2:0
- Up to 4K 120fps in 16:9 H.265 10-bit 4:2:0
- Up to 4K 60fps in ProRes 10-bit 4:2:2
- Up to 4K 30fps in ZRAW (you can use the free downloadable ZRAW suite to debayer the image)
- Up to 2.7K 160fps in H.265 10-bit 4:2:2
- Up to 1080p 120fps in ProRes 10-bit 4:2:2
- Up to 1080p 240fps in H.265 10-bit 4:2:0
- Dual Native ISO 500 & 2500 (in WDR mode it is 250 & 1250)
- Can record in H.264 in select resolutions and frame rates for more relaxed projects.
- Has a WDR mode in 4K at up to 60fps or 1080p at up to 60fps for 2 additional stops of dynamic range (13 in total). It does a 2 x 2 pixel binning to capture two simultaneous exposures. The readout rolling shutter speed at 1080p in WDR is very decent.
- The WDR mode can be recorded in ProRes at up to 60fps in either 4K or 1080p
- The fastest rolling shutter speed is around 10ms at 4K @ 60fps recording.
- All high frame rate recording always records audio as well.
- You can also set User Profiles for quick settings changes.
- Very low power consumption 12 watt maximum
- Can use an Apple iPhone via USB-C to view and control the camera. The lag using this method is faster than using an HDMI monitor.
- I would recommend joining the ZCAM E2 facebook group to stay up to date on all of the updates that are upcoming for this camera such as the TOF autofocus module. The CEO Kinson is on there 24/7 which is great for taking feedback and staying in the loop.
- This camera is compatible with the Portkeys BM5/BM5ii monitors for touch screen control.
WHAT IS INCLUDED:
1 x ZCAM E2 body
1 x Smallrig Cage
1 x Body Cap
1 x Power Cable
