Media_Alchemist
Re: HDFury for HDMI capture?
Hi.
Long time lurker, but long time user of both a GH1 and GH2. I thought I’d pass along some observations I’ve made with some recent HDMI testing I’ve done. Maybe it will help someone out. I know many of your posts have helped me out.
I just purchased Veescope Live to use the scopes for a keying project I have coming up. I’m using it with a Matrox MX02 Mini and a 2010 Mac Pro hexacore and the GH2.
My initial plans were to record in camera to one of the hacked settings, but I noticed that Veescope Live can record directly to disk to Prores HQ. So just to confirm what I’ve read online, I tried recording directly via the GH2’s HDMI out.
As expected it outputs 8-bit at 60i and there are issues even when you do 2-3 pulldown on the footage. I know there is a long AVISynth thread about HDMI capture, but I’m on a Mac and there just seem to be a lot more steps than I’m interested in doing. So instead I followed the steps posted on ablecine.com here for 2-3 pulldown in Apple’s Compressor. http://blog.abelcine.com/2011/08/19/simple-workflow-for-removing-23-pull-down/
This is where I tried something different. I recently retired an HDFury 2 from an older component only HDTV. The specs for the HDFury 2 are here. http://www.hdfury.com/products/hdfury-ii/specs/
Since the Matrox MX02 Mini can capture via component too, I connected the output of the GH2 to the HDFury 2 to convert the HDMI to Component. It seemed to work without issue. So I captured the footage to Prores HQ via the component capture and followed the Compressor steps posted in the ablecine.com blog link above to remove the 2-3 pulldown.
It seemed to work for the most part. At least the weird interlacing issue even after pulldown removal seems to be gone. In the picture I attached, I first notice the difference in the PowerRanger’s hand and face. Otherwise some of the issues with the reds still seem to be there, plus there is a shift in gamma, but that may be addressable in camera, 5DtoRGB or in post.
I just hoping someone more familiar with this may experiment and come up with a valid workflow.
Here are the settings I was using.
GH2
Lumix 14-140mm lens
f/5.8 50 ISO 400
24p Smooth -1 -1 -1 -1
indoor white balance
Veescope Live’s input was set to Matrox MX02 Mini 1080i 59.94 YUV 8-bit
Edit: Sorry, the pictures I originally posted were so compessed you coul't see the details. Just veiw the Flickr ones for now. I’ll post the videos if I can get a recommendation where to post them. They are about 400mb each.
Edit: Added photos on Flickr http://www.flickr.com/photos/53780076@N08/7122338285/in/set-72157629920240125/
Again I’d like to thank the GH1 & GH2 community for all of their work.
Hi.
GH2
Lumix 14-140mm lens
f/5.8 50 ISO 400
