ectobuilder
Re: Flash
I'm thinking about getting a bit into photography.
So question I have is what are the disadvantages vs advantages of:
- Triggering external flash using an external transmitter vs an internal transmitter in the DSLR?
- Using manual controls vs TTL/E-TTL/A-TTL?
Also, if I intend to use manual controls ONLY, is it necessary to purchase a $600 flash? Or would say a $100 flash from an off-brand be ok?
And in general what should I look for? One requirement I have is I want a flash that has a maximum power output so that I can shoot at F22 or even F32 if needed or equivalent and is somewhat durable (doesn't overheat too easily). Also, being able to control (adjust settings) each flash from a single remote location is a plus.
