Greetings,
I have edited an entire feature on AVID XPRESS. It was shot with the HVX200 using a firestore 100. The entire film was shot on 24p (non-advanced) and edited at 1080i/59.94. I have outputed a 1080i/59.94 to HDCAM, HDV tape, and Various NTSC Digital Beta Masters.
The client now wants a HDCAM 1080/23.976p Master. The post production editing house in L.A. does not want me to use a Snell & Wilcox frame rate converter due to its issue of occasionally creating a digital artifact going from 1080i/59.94 to 1080/23.98p. The editor (who uses FCP) told me the best way to do a pulldown removal with MXF files is RAYLIGHT MXFX. Which i happen to own.
A) what is the easiest way to do this pulldown removal using RAYLIGHT MXFX from one project to another. Can i use the same EDL?
and
B) uh slight problem, when I initially imported all my MXF files into AVID I broke up the original CONTENT folder and dragged all the MXF files from the VIDEO and AUDIO folders into AVID MEDIAFILES subfolder MXF subfolder 1
When I either try to drag the AVID MEDIAFILES, MXF, 1, or the actual MXF files, into RAYLIGHT MXFX, Raylight will give me an error
XML PARSING ERROR INSIDE FILE
How do I do pulldown removal from MXF files that are already sorted in AVID MEDIAFILES folder? and how can i relink the EDL from a 1080i/59.94 project into a 1080/23.976p project
By the way
I have been working on numerous features (simultaneously) and it seems that every client wants a different type of format. I wish i knew before that a 1080/23.976p master was the way to go and easiest to create other masters (PAL, NTSC ETC.) I guess for anyone that ever has problems the way to go is always edit on 1080/23.98p and create your master this way, to make life easy on deliverables.
I have been stuck in the world of Domestic TV for 2 years and every contract the deliverables were always Digibeta NTSC or 1080i/59.94. Now i know ugh. If anyone can help with this RAYLIGHT question, it would be greatly appreciated. ugh
thanx,
Zack Snygg
and
By the way
thanx,
Zack Snygg
