I started to play with the Raw file out of the Atomos Shogun (the first generation).
On the FS5 I use the S-Log2/3 for the exposition setting as I was also recording XVAC internally.
The CDNG file out of the Shogun is very much under exposed, I understood that on the Convergent Design 7Q+ that’s the same situation, you have to use a LUT on the recorder to properly expose the CDNG file.
The down side is that you overexpose by a large amount the internal XVAC file.
How about the Sony Raw out of the AXS-R5, is it the same situation?
