magicmack
First off I hope this is in the right section.
So here is just a short commercial that we shot for the Doritos Guru Contest in Canada. We put a lot of work into it and the results came out pretty good.
One problem is the lighting which was very bad in a lot of the shots. We tried using a Chinese lantern for most but, it had a low wattage bulb so it didn't give off enough light.
For the first opening shot we used a simple, cheap, DIY dolly that we built for under $40 Canadian. The whole thing was shot on the Canon GL2, edited in Premiere Pro CS3.
I think the voting is only open to Canadian residents, so if you are from Canada your vote would be greatly appreciated.
http://www.doritosguru.ca/mmclean/RanchyFiesta-Therapy
-Thanks
Comments would be great to hear!
-Thanks
