Rain machine
JPUSC
How do you create rain for a shoot? Is there a special contraception for this, maybe something that connects to a hose or water source? Actually, is a hose pointed downward enough?
...and what's the best lighting setup for this?
Thanks! :Drogar-Happy(DBG):
my guess would be to get some pvc pipe, connect to a hose with a sprinkler head like the ones you see in buildings to extinguish a fire. My guess.
Point the hose upward. You want the water drops to be falling, not squirting out. For a cheap rain device get a long lenght of PVC pipe overhead, and put sprinklers on it, pointing upward, and let it just fall down naturally.
But if you need to cover a large area, that's a lot tougher obviously.
Light from behind. The only way rain will show up is if it's lit from behind. If it's day, it helps to have a dark background too. See the cine extra on Rashamon.
-J
Also I second what Barry said. Unless you are shooting under trees that will interfere, just shooting the hose straight up and letting it fall will provide a good effect. Building a PVC rig may be overkill for most situations and provide only a marginal improvement in rain quality. It'll also limit your flexibility.
It can also help sell the effect if you have a second hose sending rain into the background, an often forgotten aspect of rain is that tends to rain in other areas other than where your talent is standing!
-J
If you insist on using a contraception method, well then you could always use the old "poke a bunch of small holes in a condom and stick it on the hose" method. Just make sure you don't accidentally use it afterwards because it doesn't work too well for its original purpose at this point.
I have seen an interview whit a FX person, and they used this things thats in the roofs of building, that in case of fire, will sprinkle water. They had one of those things on a hose, and it made good looking rain. Easy as hell as well.
