davidpula
I am editing 24p (23.98) Prores footage in FCP and having issues with the resultant Quicktime conversions. The same video that plays smoothly in the Final Cut timeline has a random "choppy", jittery, stuttering thing happening when the exported file is played in Quicktime. Every second or so there is a jump, or stutter, which is more accentuated with more movement or panning in the image.
I have googled this to death and found many others complaining of the same problem. I have yet to find an answer.
I have played with the settings in dozens of combinations. Under "Using Quicktime Conversion"---h.264, MPEG-4, Photo JPEG, Sorenson, even AIC and a few others. I've tried bit rates of 2 to over 100mbps. I've played with frame rates (current/24/23.98/23.976). Mostly I left Key Frame at "current" but also tried 24, and lower and higher numbers. Also tried various compression settings (low to very high).
All of these came out pretty much the same. The best compression in terms of these video jitters was actually Photo JPEG. H.264 was the worst. But even Photo JPEG is still not great. A similar, halfway OK method was also simply choosing Export--Quicktime Movie--Current Settings. This of course gave a huge file of 117mbps but I then compressed that in Quicktime itself and ended up with a 3mbps file which looked pretty much the same. So-so. Ok but still a bit jumpy.
The timeline I worked in was completely rendered and everything plays very smoothly during playback in FCP.
I'm using FCP 6.06. and Snow Leopard. I had this same issue when I had Leopard. I was using the new Quicktime X which came with Snow Leopard and then changed my default app back to my former Quicktime 7. Quicktime X is an utterly idiotic downgrade which displays less clip info and doesn't even offer Preferences. Both showed the jitter bug. I'm reading that people with all different OS's and versions of FCP and QT are dealing with this bug.
Anyone else had this incredibly irritating problem and found an answer? I don't see so many videos on Vimeo with this jitter.
Help please!
Help please!
