T theos Veteran Oct 11, 2004 #1 Hi guys, anyone knows what slot the lacie combo pci card (usb2/firewire) should be in on a g5 dual 2 ghz . . . slot 2,3,4 are 64-bit 33mhz . . . and slots 2 & 3 are 64 bit 100 mhz, slot 4 664 bit 133 mhz! which slot! ???
T theos Veteran Oct 11, 2004 #2 Re: quick help installing lacie firewire pci on G5 Re: quick help installing lacie firewire pci on G5 0 reads but solved it i think . . . yes I opened up the g5 . . . not mine though and had to install a new set of fire wire ports.
