Questions regarding Totevision 703
rogha
I have just bought Totevision 703HD Kit. The monitor will be used alongside my HVX. I need help with this product.
After I play around with it, I come with few questions.
1. I found that the color as not as real as I look at the viewfinder of my HVX. Normal after reset, the red will look orange. And after adjustment with the color bar, the color seems to become more screwed up as it goes away from the supposedly color marked by the color bar. Is it normal? Is this monitor to be used for focus monitoring, for assisstant camera/focus puller best friend on the field?
2. I'm planning to use two monitors, one for the asst. camera and the other one for the client as my job will be done for the commercial etc. I just found out that connecting component cable will leave out other connector (S-Video, RCA) unused.
I want to be able to view it on two monitors. One with component (as it will be HD) and the other, for the client, could be the RCA or S-Video. Can I do that?
Or can I connect the input of the monitor with the RGB Component, and have the out of the RGB Component daisychain the signal to another monitor capable for the RGB Component connection, can I do that?
Anyone can help me in these matters?
Hi rogha, I use the totevision, i find it completely useless for color. I use it only for framing and focus thats why i got it. If you want a color accurate monitor you will need to get something else. Its great for focus pulling, i use it in combination with the foxi.
If nobody shimes in i will try the daisychain process trough the totevision and report back.
Regards
Pierre
BTW aku belom sempat nonton perempuan punya cerita, aku skrg dah pulang ke canada, mungkin waktu aku ke indo lagi sudah ada dvdnya.
Please, inform me on your finding regarding this.
Especially with component out from HVX to RGB in to Totevision and RGB out (next to the in slot) to monitor with RGB input capability.
BTW. Indonesia loe lumayan juga yah. Shooting sesuatu ngga waktu di Bandung?
