BerkeCreative
I don't want to create a bunch of new threads, so I thought I'd try to cover everything in one post. I'm pretty sure most of this stuff hasn't been covered here before. But sorry if I missed it!
I’ve been using the LT about 8 months now. I love the camera. But I have certain issues I’ve been encountering over and over again on productions. So I wanted to ask the community some questions and maybe use the opportunity to direct some feature requests towards the very helpful Mitch Gross. I’m not looking for pie in the sky 120fps 4k Raw requests. I’m asking for small usability tweaks that are (hopefully) solvable to some extent with firmware updates.
SDI Outputs:
Why is PsF still a thing? Especially for 24p (23.98)? Is anyone actually live switching cameras at 23.98? Or recording to tape?
Isn’t true 23.98p part of the SDI spec now? Every monitor/convertor I’ve used seems to support it.
PsF however, isn’t supported on many common converters and wireless transmitters. I have to use my Odyssey or Gratical EVF to do a conversion for wireless transmission. I can also use the VF SDI Out for these kinds of applications, but with some huge compromises. More on that.
Plus PsF adds a bunch of processing delay to many monitors.
REQUEST: Please give us an option for non PsF framerates on all SDI outputs!
In general, I can’t fully understand the thinking behind the differences between the VF SDI Out and SDI OUT 1 & 2.
VF SDI Out:
It’s incredibly useful to be able to change the format of this output. This is a workaround for converters and transmitters that don’t support PsF. But I can’t seem to get sound, or timecode, or record tally information on the VF out. Am I missing an option for enabling this?
It’s so nice that Panasonic supports third party viewfinders and monitors on the LT. But they are kind of crippled without the ancillary data.
Is it possible for the VF SDI out to support audio and timecode at the least? Even if that means that you have to use the project frame rate (non PsF of course!!)
REQUEST: Please add TC and Audio to VF Out
SDI Out 1 & 2:
These outputs support audio, timecode, recording flag. This is great. But the output format and frame rate seems to be completely locked to your main recording format. So once again I’m stuck with 23.98PsF for 99% of my shooting. I can change the SDI 2 to the VF Output. But then sound and timecode once again stop working. Plus now I can’t send a clean feed from that output without turning off my viewfinder overlays as well.
REQUEST: Please give us an option for some limited frame rate conversion on SDI outs 1 and 2. It’s already on the VF output.
Monitor Volume:
Is there a way to have separate control of the internal speaker volume vs the headphone out? I don’t really use the internal speaker except for playback. I guess I could use a dummy plug in the headphone jack. But I was hoping for a more elegant solution.
Timecode:
This is minor, but it’d be great to have a quick option to set the camera to time of day timecode. Docs love this. The camera stores the time info anyway.
ABB:
When shooting LOG the ABB option is in MENU>CAMERA SETTINGS>BLACK.
When shooting with a scene file the ABB option is in MENU>SCENE FILE SETTINGS>BLACK.
I guess what I’m asking is, is there a difference between these two ABB options? If the camera has been recently black balanced while in V-Log, is it best practice to re-balance when switching to a scene file using the scene file ABB option?
IRIS Wheel Options:
Would be great to make the IRIS wheel more programmable when using non-ef lenses. I love that direct audio control was added. But would love to see white balance and ISO added to the programmable options. And just a press in of the iris wheel to activate those options. It stinks to have to waste a user button on changing the function of the iris wheel.
Card Format:
I recently discovered that you could format cards from the Control panel without diving into the ‘deep’ menu. But that functionality seems to be missing from the ROP app. Would be great for AC’s to be able to format the cards from the app.
NR:
When exactly is noise reduction active? The manual is super confusing here, but it sounds like it's only active when recording in an LT codec. Is this correct? I can't see any difference on the monitor outputs. Even when zoomed in 1:1.
SDI Lag:
I read somewhere that one of the last firmware updates was going to have a feature to reduce lag at the SDI output. Was this implemented? Is there an option to enable this or was it just implemented behind the scenes? I haven’t noticed a significant difference in monitoring lag.
Please post if anyone has thoughts, or workarounds, or corrections. Or other REASONABLE feature requests. Lets not start asking for them to add hardware knobs in a firmware update =-).
Also I’m sure Panasonic is well aware that we’d like to reboot the camera a lot less.
SDI Outputs:
VF SDI Out:
SDI Out 1 & 2:
Monitor Volume:
Timecode:
ABB:
IRIS Wheel Options:
Card Format:
NR:
SDI Lag:
