Questions about the Atomos Inferno Set up
greytail
I am trying to understand how to operate the Atomos Inferno properly. I am connecting my FS5 (raw) via SDI. I have read up on how you are only supposed to use Preset 7 and how to expose for S Log 2. But, I don't understand what I am supposed to do on the Atomos, beyond selecting the my Pro Res and reading the various graphs. In one of the menus it shows Rec a 709 and then an ATOMHD Button and so forth. So, these are controls that only effect what you see on the monitor, right? Unless you select Log to Video? So what is the default mode on the Atomos? If you start recording with the SLOG-2 selected on the camera, are you recording SLOG-2 on the Atomos not matter what? When you initially turn on the Atomos it comes up with the Rec 209 button already lit and you can't turn it off. So yes,I have read the manual and still don't quite understand what is going on. Hopefully someone here will be kind enough to set me on the correct path...
