Denniscasey
Per previous posts I am learning to use Sony a6000 and Canon EOS 70D so I can decide which one to keep and give each one a fair trial. I watched a Sony Tutorial at this link
http://www.sonydigitalimaging.com/sony_tips/select-a-focus-mode/#.VD6sRRZbXEZ (go to link then select Shooting Video and then to second "box" Shooting Movies). In this tutorial it shows a video being shot of a lady shooting an arrow at a target. While filming it shows focus point first on lady (sharp focus with target blurry) and then focus point moved to target (lady now blurred, target in focus)--this happens at around 2:16 into tutorial. Sony uses different cameras at different times for these tutorials and not using a6000 for this video since they say in Menu "select Local in Focus Area" to do this "rack focus."
Since a6000 does not have "Local" as a selection in Focus Area options I called Sony tech service. They could not help but thought "Spot Focus" might work. Since then I have Googled more and found following suggestions:
[FONT="]You press the center button to activate, then the C2 button will center[/FONT][FONT="]. [/FONT][FONT="]I think this guy meant select Flexible Spot and then move spot to where you want and then pressing C2 will center spot. [/FONT]
And then another suggestion to move spot
[FONT="]While you can use 2 wheels to move the spot you don't "have" to. You can just use the d-pad function of the click wheel.[/FONT]
So far this seems to work for taking still photos (at least I can get Spot Bracket to appear and I can move it around including using C2 button to center it) ,but I can not make it work in Movie Mode. I can get the Spot "bracket" to show on LCD (but ONLY if I select something other than Program Auto in Movie Mode) and I can move the spot around ok. However as soon as I press the movie record button to shoot video the "spot brackets" disappear.
Can someone please explain how to do the "rack focus" shooting video with a6000?? I have tried three different Sony tech help people and so far no luck--no one says it can not be done, they just can not figure it out.
I will Google "the d-pad function" as mentioned above, but this is also a question I have (just beginning to learn camera). Dennis
[FONT="] [/FONT]
[FONT="] [/FONT]
