Brian@202020
I see on Nanoflash.net there will be a bracket coming out soon for mounting the Nanoflash to the AF100. Do you have an idea when this will be out? Where will it mount to? Do you have pictures or a CAD drawing you can post?
Dear Brian,
Olof, one of our supplies, and a great mount designer and manufacturer, is preparing a mount for the AF100.
I will attempt to get more details today.
Dear Brian,
I have heard from Olof.
He is waiting to receive his AF100 so that he can check, and adjust if necessary, the mount.
Olof is very responsive, and you can purchase his mounts from www.nanoFlash.net
I will be working on 2 different bracket systems for the AF100, these are my initial ideas:
1. A handle replacement with NF and battery holder, for a very compact system. There will still be a handle there as well.
2. A shoulder brace with a wing for the NF and batteries to balance the AF 100 for shouldering, with an optional Rod system up front.
I have an idea that involves a quick change setup so you can either use the compact handle setup or the larger system.
As soon as I have the AF100, we are all waiting right, I will work out the exact design.
Someone should design a recorder in the shape of the handlegrip, and it would just replace the existing handlegrip (the one on the side).
