AndrewTaran
Do you use any support for adapter + lens?
After 2 month of use Canon mount starter to rattle(even though I didn't use my heavy 70-200 pretty much at all) so I had to tighten up the screws and started using a support - it has a female 1/4 thread, so I've put a longer plate on my FS100, couple spacers and it seems to work fine(I've been using it for 6 months). Though for event shooting I want to use my 18-200, which is surprisingly sharp, but then taking out a Metabones adapter becomes a hassle - I have to unscrew it, remove spacers and then remove an adapter. And to put it back I have to do the same routine over and over again...Will probably try to use my Metabones without support and see how it performs this time. So I was wondering if anyone have experienced the same problem as I.
Thank you
Thank you
