DVX100percent
Dear Jan,
I have a problem with my camera that I have described more then once in this forum. It seems that a few other people are having it as well. It's the one when the camera intermittently reloads the tape while in standby. It can happen as often as every 15-30 seconds and then it might not happen for a few minutes. Occasionaly (very occasionaly) there is a tape which works perfectly without reloading. It usualy starts a few minutes into the tape (never when you just put a new tape in), and gets worse towards the end of the tape. The whole reloading cycle takes about the same time as when you first turn the camera on (about 30 seconds) and sounds about the same. Needless to say it is very annoying and I lost a few shots because of that problem.
Camera was in the shop for three weeks for this, and all they said is they couldn't replicate the problem, even though I showed it to them when I brought it in.
Where do I go from here? I want it fixed but can't afford to lose it for another three weeks just to be returned to me again with the same problem. They did clean the heads though, but it didn't fix the problem. I only use panasonic tapes, by the way (just thought I would clear this out of the way before you ask).
Thanks in advance!
Thanks in advance!
