Question about the Olympus 14-35mm f2.0
Seamus McFlannel
I've been looking at the Olympus 14-35mm f2.0 as a possible complement to my Nikon lenses
as I have nothing that wide. The question is: How does it work with the AF100 if it has no aperature ring?
I can't seem to find any info on this anywhere, and the people I'm buying from at Abel are hosting an event today.
Thanks.
You need the 4/3 to Micro 4/3 adapter. It will allow you to use the wheel on camera to adjust aperture.
*Logan beat me to the punch
The camera electronically controls the iris with the aperture dial/wheel on the camera. Apparently you get what fstop you at on the LCD screen like a dedicated fixed lens would do. You'll of course need the Lumix/Panny 4/3 to M4/3 adapter.
Yes, i can confirm f/stop shows in evf/lcd of AF100 and the lens will autofocus when you push the focus button on the camera. Lens weighs 2 lbs, just under the 1kg suggested max. unsupported lens weight. Jan said I could get away without rod support but I can still rig my Zacuto baseplate for added support.
Here is a photo of my lens on the AF100 at DC's GVExpo Wed.
Chris,
What do you think of that lens? I've been reading up on it and it looks like it is a nice piece, both mechanically and optically.
Just got the lens recently specifically to use on the AF100. As you know it is f/2 all the way thru from 14-35. This was same lens Phil Bloom used a lot on his recent Japan film- I recall that some of the shots in the car of the driver especially. Optically the lens is a superb performer even wide open. This lens and the 35-100 f/2 are top of the Oly line. It is large and heavy at 2lbs, but built like a tank. It must be used with the Panasonic adapter for 4/3 lenses so you can read your stop in the evf/lcd and autofocus (not continouos!)..
The lens breathes very littlle, but of course being a still zoom lens it won't hold perfect focus whilst zooming. You might get away zooming from tight to wide especially stopped down a little, but if focused at wide you will lose focus when zoomed in tight. I have not yet checked if lens is perfectly centered whilst zooming.
It will work terrific as a variable prime lens and focuses down to 14". I think the 35-200 min. focus is only 4.5'.
Focus/zoom rings have a nice thick, well-packed feel. I may be able to manually creep in/out with this lens a bit if it'll hold focus. I've only been able to check this lens on my GH1 still camera but I think it will be a terrific performer on the AF100 until something better comes along.
chris
I
Panasonic DMW-MA1 Mount Adapter to Mount Four Thirds Lens on Micro Four Thirds Camera can be found at the usual places - Abel, B&H, etc for $105.
VariZoom VZPFI Focus/Iris Controller should be able to remotely , manually focus and change iris but I have not personally tested this yet. It would be great if you could read your focus distance in the EVF/LCD of the AF100. Abel sells an AF100 bundle that includes this controller along with both of the Oly F2 zooms so it must be compatable.
chris
I've been looking at this lens too as my first "kit lens" for my AF100 that I've reserved. You said it would work well as a variable prime? I don't want to spend the cash for a set of zeiss primes if I could get away with this for a bit before investing in a set of primes.
I'm just concerned with getting a good shallow depth of field without having to spend $4k on a set of 3 zeiss still primes right off the bat.
You could easily use the 14-35 as a variable prime; it is a fast f2 through out it's range and it is optically outstanding as a google search of reviews will reveal. Footage shot at different focal lengths will all match as well, of course.
So , yes, you could "get away" with this lens. Shallow depth of field is not the sole sanctuary of the Zeiss primes, but Zeiss glass will have a different signature look from the Oly glass (bokeh, warmth, etc.) but I haven't had the opportunity to compare the lenses. Also the Oly zoom is a still lens adapted for cine/video use - distance markings are closer together than the primes making focusing more critical and since focusing is internal, there is no way to make witness marks unless using a dedicated follow focus rig.
FWIW, Phillip Bloom owns the same lens and has ordered the 35-100 as well.
Look at it this way, instead of being restricted to just 3 focal lenghts, you will have your choice of 21 lenses that will all match : )
