Hello,
Read here and there about how to create profiles for the AF100 I came upon the Marvels profile, this one here:
http://marvelsfilm.wordpress.com/2011/08/08/panny-af100-af101-flat-picture-style-for-cinematic-look/
and in bottom of the post there is this info: " Update: If you use the Cine-D gamma setting, you should consider lighting the scene following old-school film practice: 55IRE max on faces! You will probably apply a curve to the picture, or adjust contrast and/or gamma in post -> kicking up the middle range up to around 70IRE again. Lighting caucasian skin over 55IRE with Cine D will result in problems if levels are lifted in post. "
Why should I put 55 IRE max on the faces ? Is it because I will bring the up in post as a consequence of this gamma being a little flat and they will end up being washed out ? Is this a good practice to follow when using any cinegamma on every other camera that has these options ?
And are the zebra options the same as when using the waveform, I mean, If I put the zebra at 70 is it the equivalent of 70 IRE on the waveform ?
