scorsesefan
Coming from the FS5 I have a few questions about the FS7's EI mode. My understanding of EI mode is that the FS7 always shoots at 2000ISO in EI mode (the sensor's native ISO) and that changing the EI only affects the LUT image on the monitor, not what the sensor records. By setting the EI to, say, 1000 in SLOG 3, you would open up 1 stop and you're effectively ETTR and therefore lifting your shadows and the result is less noise. Is this correct?
But what about bright scenes? Should you be using a higher EI than 2000 to protect your highlights? All of the above is with a rec709 lut.
