Can someone inform me please about bokeh. I just read that a full frame sensor and lens system like the Canon 5D Mkiii equipped with an 85mm portrait lens can make better bokeh than a 45mm Olympus lens attached to an AF100. This is because the full frame sensor and the big lens do a better job of it. But, what happens if you take a Canon 50 mm lens or perhaps the same Canon 85mm lens and stick it on the AF100 with a decent adapter like the Redrock Micro Live Lens? Do you get the same effect as from the Canon? Or, can the AF100 never achieve the same effect no matter what lens you use because micro two thirds just can't do the same thing?
Sorry if this sounds a bit ignorant but I am trying to understand what lenses I need to use to achieve the same effect as those Canon 24-70mm and 85mm and Zeiss 85mm.
Thanks in advance
Greytail
Thanks in advance
Greytail
