r3koehler
I am having some quality issues with DV footage during import. I am running Avid Media Composer v2.5.2 with an SDI Mojo. The footage was shot 23.976 on miniDV. I am importing using the panasonic DVX100B it was shot with via a 4 pin to 4 pin firewire into the back of the mojo. I am in a 23.976 project using the advanced 2:3 3:2 pulldown importing through host 1394. I originally imported the footage in DV25 and the footage appeared a little too compressed for what I'd like. So I figured I'd try it a couple different ways to see if I could get a better result. In 1:1 I got the same result as the DV25 and it wouldn't let me capture using DV50. When I hook the camera up directly to a monitor using an s-video cable the picture is crystal clear. Is it the fact that I am am going through firewire that I am losing this quality, would capturing using an s-video connection correct this, or what should I be using as the best uncompressed setting during import? Any suggestions would be much appreciated.
On a seperate note I was curious if using a firestore device, instead of tape, would solve the whole compression issue from converting to the hard drive. The question with this is, if the firewire connection is the cause of my above problem, would I have the same problems using one of these, being a device that requires a firewire connection?
Ryan
Ryan
