QT Native 23.976
Rocksun
Is their a way to transfer a Quick Time 23.976 Native File recorded in the FireStore FS-100 into a another file preferably MXF.
I have footage that was recorded at the this wrong format for me to edit with in Avid. Im trying to convert this footage so it will be compatible with my Avid Editing software on a PC. Any suggestions would be very helpful... thank you.
Find someone with Edius, have them drop the QuickTime file into a sequence, and then print to a P2 card (or an MXF structure in a folder on a hard drive).
Edius can output to P2 cards and split the output as each card fills up.
You can try Raylight Decoder ( http://dvfilm.com/raylight/decoder ) $95 together with Quicktime Pro, and encode it to DNxHD, or possibly drag it straight into Avid instead, but it won't playback real time unless you transcode to an Avid codec.
