boomstrikevideo
For a long time I waited until an HD camera came along that had the capability of the HVX in a package compact and light enough for a large helicam. At a bit over 6 lbs. it works quite well but at that weight I still have to add about a lb. of ballast weight to the tail of the helicopter to get good balance. The performance of the helicopter, especially at high altitudes on hot days would improve dramatically if I could reduce the weight even more. Looking at the camera tonight I realized that the handle adds no value to how I use the camera and is usually in the way. My question is, can the handle be easily removed without causing any operational problems to the rest of the unit. I had hoped the mic, IR sensor, record button and zoom toggle could simply be unplugged and the handle removed. Anybody know for sure? Are there any other areas to reduce weight or size?
