/usr/local/bin/
vup-start.sh
BMP_PATH=/usr/lib/p16
BMP_START=update_title.p16
BMP_END=update_end_title.p16
BMP_ERROR=update_error_title.p16
vupfb
vupfb f [p16 bitmap imagefilename] : Display bitmapfile.
vupfb p [progress value(%)] : Update progress bar.
vupfb m [message] : Update message string.
vupfb bp [value1(%)] [value2(%)] [time1(us)] [time2(us)] [count]
: Brink progress bar.
vupfb bm [message1] [message2] [time1(us)] [time2(us)] [count]
: Brink message string.
vupfb i [PAL/NTSC] : Initialize VGA
./pcmcia/spd_mod.o
<3>[spd]4:%s:%d:<spd%c>R5C812 on Unkown
<3>[spd]4:%s:%d:<spd%c>R5C812 on WRITE
<3>[spd]4:%s:%d:<spd%c>R5C812 on READ
<1>[spd]2:%s:%d:<spdu%d>ALERT:P2card firmware size 61h only but size=%02xh
pcmcia-config/spd
#!/bin/sh
#echo "P2 CARD ha syudou de maunto sitekudasai :-)"
/kernel/drivers/ieee1394.master/sbp2master.o
description=IEEE-1394 SBP-2 protocol driver
parm_desc_sbp2_max_speed=Force max speed (3 = 800mb, 2 = 400mb default, 1 = 200mb, 0 = 100mb)
parm_desc_sbp2_serialize_io=Serialize all I/O coming down from the scsi drivers (default = 1)
parm_desc_sbp2_exclusive_login=Exclusive login to sbp2 device (default = 1)
parm_sbp2_force_inquiry_hack=i
parm_desc_sbp2_force_inquiry_hack=Force SCSI inquiry hack (default = 0)
author=Ben Collins <bcollins@debian.org>
/home/makoto/workdir/myapplication/p2pf_K230/src/contrib/K230_Kernel/include/asm/pci.h
SCSI emulation for IEEE-1394 SBP-2 Devices
pcmcia-config/spd.conf
# Configulation file for nsp_cs.o
device "spd"
class "spd" module "cb_enabler", "spd"
# OEM
card "Panasonic P2 Card"
pci 0x10f7, 0xf8206
bind "spd"
# end
mntp2
### Manual mount script for P2card (multi cards)
### 050527 : add K230(2slot) devfn check by env value HOSTNAME.
if [ `mount -t msdos /dev/spd${letter}1 /mnt/spd${letter} -o spd,noatime 2>&1 | wc -l` -ge 1 ];
then
echo "### Please format % /sbin/mkspdfs /dev/spd${letter}"
exit 1
fi
/kernel/drivers/scsi/scsi_mod.o
MATshi*A
RocketStor 500S
RocketStor 2000
pcmcia-config/config.opts
# First built-in serial port
exclude irq 4
# Second built-in serial port
#exclude irq 3
# Options for Raylink/WebGear driver: uncomment only one line...
# Generic ad-hoc network
/usr/bin/perl
vupled <ON time(usec)> <OFF time(usec)> <Blinking count>
getshinfo
getlog, dumpFlashRom, dumpMbus, dumpSram
/sbin/
cytune
Usage: %s [-q [-i interval]] ([-s value]|[-S value]) ([-t value]|[-T value]) [-g|-G] file [file...]
Can't issue CYGETMON on %s: %s
elvtune
util-linux-2.11h
usage:
elvtune [-r r_lat] [-w w_lat] [-b b_lat] /dev/blkdev1 [/dev/blkdev2...]
elvtune -h
elvtune -v
%s elevator ID
tunelp
, on-line
, out of paper
, ready
, busy
Usage: %s <device> [ -i <IRQ> | -t <TIME> | -c <CHARS> | -w <WAIT> |
-a [on|off] | -o [on|off] | -C [on|off] | -q [on|off] | -s |
-T [on|off] ]
2.11h
Does Perl remain in the firmware?
I'm a big fan of printer supportInstead of P2 cards we could just bring a few cases of paper.
Here's another low-hanging fruit. Integrate support for the framerate hack so we don't have to load it from SD when we want it. That should be super-simple, right?
I cant find it in my notes but both here and in other locations I found a couple drivers that indicate some sort of PCMCIA slot based network or serial connection which is probably how debugging is handled. I still really need to explore this more and it is high on my priority list because while I can already debug by running my own scripts from the SD card and printing information to the LCD an interactive console is going to speed things up 100 fold.
Yes, behind the battery of the HVX there is a serial cable that connects to a PCB assembly then to a MS-DOS based computer to tweak and calibrate parameters via serial, such as display/color/tape.
