[FS: General] PT24 Remote Head
justin lovell
The Digital PT24 Head pans and tilts your film or video camera smooth and accurately by proportional joystick control. Use on Jib Arms, remote mounts, or tripod mounted and run 2 cameras with 1operator. Unlimited uses.
12 VOLT POWER -Comes standard with 12 volt AC transformer, and easily accepts 12 or 24 volt battery power through 4 pin XLR connector. (fits most battery belts)
HIGH TORQUE D/C GEAR MOTORS - The highest quality Maxon coreless motors are used on the PT30. Additional motors available at gear ratios to 3000:1 for movement so slow it can't be seen. We can supply motors in different ratios for only $15 per axis, or order more for different applications. (Additional Motors at $224.00 per axis)
30 POUND CAPACITY -Our most powerful and strongest head can handle your largest or smallest camera.
JOYSTICK CONTROLLED - Proportionally controlled from top quality joystick mounted directly in the control unit.
20 FOOT CABLE - Cables come standard at 20 feet.
http://www.cameraturret.com/pt24.htm
$1475 vs new $2199
