SOLD PT 20 Head $1200.00 + Shipping
Status
Not open for further replies.
BrianMurphy
  • Linear Joystick - Each degree of movement reflects and equal amount of speed increase.
  • Logrithmic Joystick - In the first half of the joystick movement, each degree reflects smaller increases in speed. Second half of joystick movement increases faster to catch up to full power. This makes slow speed more controllable yet keeps top speeds available if necessary.
  • Deadspot - Opens the center of the joystick where no movement of the motors occurs. This way you can set it to your abilitites and insure no crossover to the other axis when not wanted.
  • Speed Control - Limits top speed and spreads the new speed over the full movement of the joystick. Creating more accuracy where needed.
  • 12 Volt Power - Comes standard with 12 volt AC transformer, and easily accepts 12 or 24 volt battery power through 4 pin XLR connector. (fits most battery belts) Or optional 24 volt power supply.
  • High Torque D/C Gear Motors - The highest quality Maxon coreless motors are used on the PT20. Pan and Tilt speeds from 1 rev. in 10 minutes to 6 RPM at 12 volts and 11 RPM at 24 volts.
  • 20 Pound Capacity - For cameras as small as DV up most broadcast units.
  • Joystick Controlled - Proportionally controlled from top quality joystick mounted directly in the control unit.
  • 20 Foot Cable - Cables come standard at 20 feet.
  • Comes with a 7" Varizoom SD Monitor kit in case with batteries and charger.
    Everything in a Pelican Case, Excellent condition very little use. Just the head is for sale not the camera.
  • NOw $1000.00 + shipping including thte above monitor and a SIgn VIdeo Zoom control
Status
