G
Guest
Guest
since i received my camera, it has flashed 'psd ng', which the manual informs me means there is a problem with the camera shake detection. it does not, however, give instruction on how to either remedy the problem or turn the warning off. is this a real problem, or is there just something set somewhere in the vast menu that needs to be turned on/off? i shoot in 24p advanced.
i also need some advice on how anyone records audio. i have the little panasonic attachment shotgun mike, which has good levels but tends to be too much in certain situations. i don't know much about audio, so is there a quick way to turn it down if you step into a loud environment?
any help on these would be appreciated.l ???
