Nope. The point was that if the PS-Cam Digital X35 is indeed a 1080p camera with only 10 stops of latitude, its window of opportunity is limited, particularly if it's priced anywhere near $50K, since there are already cameras that appear to exceed some of those specs, and more are on the way. Some are far cheaper. Sure, the ability to do 450 fps is great, but it's of limited use in normal production.Yes, http://www.dvxuser.com/V6/showthread.php?248826-PS-Cam-Digital-X35-P-S-Technik although so far it's mostly about how eventually the HDSLR is going to get "good enough" not to justify anyone spending $50k on a professional camera that does the same thing.![]()
I think all you're seeing is two cameras that share similarities in body design since they come from the same manufacturer, P+S Technik. The Weisscam was "finished" by P+S just like they did with the SI-2K, which also shares a vaguely similar look.The PS-Cam X35 looks a lot like a rebranded, cosmetically altered Weisscam HS-2, except the HS-2 can do 1,500 fps at 2K, 2,000 fps at 1080p, and 4,000 fps at 720p.
