This is nice but will lock you out from proper dual recording- if card where you're recording full signal will fail you'll end up only with proxies. The whole idea occurred to me when I saw preview of C300II - it has an SD card slot only for proxies besides two CFAST slots.You'd be a lot more likely to get proxy recording and full-res recording on the same card -- like the F55 does.
That's interesting and good idea to look into that direction instead! How would you tackle deconstructing that protocol? (you can talk technical to me, I'm after CS). I may get my hands on CBK-WA100 some time.Also interesting - the usb port the wifi uses is apparently capable of video proxies. Not with the included wifi adapter, mind you - but with the CBK-WA100. But that means technically the USB port can receive and process video data, somehow. I've toyed with the idea of getting a CBK-WA100 so I can deconstruct the protocol. But it's far from the top of my list.
Wait, I've missed that Doug's words "same card". If that it's fantastic feature. It would save me a ton of time in post: cut HD, export with 4K without transcoding for proxies.Not sure what you are talking about because if proxies were recorded on the same card with the original footage as in F55, you could still use the other slot to do exactly the same thing.
