The compression/quality ratios of the various intra-frame compression methods are only marginally different.It is the preferred codec for some stock agencies. I thought it would be smaller then photo Jpeg. But is isn't.
And a lot of that may be encoded / recognized as Rec601, adding more complications for video processing.Photo jpeg is 8 bits.
I use catalyst to make subclips, that doesn't work in Davinci (or I can't) Davinci cannot export subclips I found out but maybe that is a problem of the 16 beta version.
If you use Premiere Pro CC 2019 on a windows machine- it's been able to transcode to Prores since Jan 2019- at least. As has Media Encoder.
I'm not interested in running any beta software, but I can vouch for every version of Resolve from 10 to 15. I doubt that they would change anything so basic as the delivery options, so you better look again. Is there no option for "Render: Individual Clips" on the Deliver page?
Yes there is, that is the way I always export clips, but Davinci (the 16 version), does that only half, each individual clip is rendered, but when a clip is cut in two it doesn't render both halfs.
The public Davinci beta versions often work fine.
