PRORES Export FROM Resolve 17 on WINDOWS! (VOUKODER)
cyvideo
Has anyone tried out this "Voukder" Prores export codec on Resolve 17 (full version only)? I'm quite surprised but it seems to work quite well and when you reimport the files there appears to be minimal shift in the scopes. There is a bit of confusion as in its config it does refer to 4:2:2 8-bit. Though all tests I've done so far, though not conclusive appear to indicate that the files are 10-bit. It's donation software. Voukcoder also has the ability to export using various other codecs, see below. You need to install both THE Voukoder 9.3 "App" and the DaVinci Resolve Studio 17+ "Connector"
Chris Young
https://www.voukoder.org/
https://www.voukoder.org/forum/thre...range-switch-for-10-bit-prores-still-present/
DOWNLOADS HERE:
https://www.voukoder.org/forum/thread/783-downloads-instructions/
