platinumseagulls
I'm looking for a HD projector to show my new film that I shot on my HVX200. Any advice on output to the highest rez for a large audience? Thanks!
khmuse said:If a DV project is shot with film out in mind and if the film out is accomplished correctly, it can be a much better viewing experience than any digital projection. If it wasn't shot with film out in mind, then it might not be as true of statement.
DavidBeier said:Could you expand upon this? Digital projection is what's going to make something shot digitally look best. That's what all the big boys want. I really don't understand how a film out which, by its very nature, is a very destructive process (usually reducing the 3200 possible lines of a 35mm negative to only 810 when projected on average), could someone achieve better results than digital projection which is designed from the ground up to work with the digital signal and keep all that's there intact.
In a lot of digital projection, you can still see faint gridlines around the pixels. This was true even of my viewing of Star Wars Episode III. Oftentimes, the projector just doesn't handle highlights and shadows are truly as film. Of course, your mileage may vary.
A film out of the same images would result is a fuller image without gridlines. Since it's film, it'll have truer blacks and truer highlights, with full brightness.
