morgan_moore
Major Contributor
There is a misunderstanding going on here. You don't use quality calibrated monitor with an assumption that the image will look that great on all consumer monitors out there. You do it so you can make adjustments to the footage based on what's actually there in the first place and only when you have your master you can sleep peacefully knowing that if someone is seeing crappy image it's because of THEIR crappy gear or THEIR crappy settings. Imagine the other way around: make your master on a crappy monitor and then you can never know if your end client sees things the way they see because of their crappy gear or YOURS.
Nope no misunderstanding. Nice monitors in nice darkened controlled rooms will allow you to see deep in to the blacks. Your punter watching on a device on the bus to work will miss all those darks and therefore miss bits of the story.
So for delivery aimed at consumers viewing on the web it is sensible basically to grade in a "smaller" space (aka critical info not to dark or light)
The ideal would be to grade on a really top end monitor and have some output luts to convert to a consumer gamma - but considering the cost of that I think the "crappy" approach is not dumb or mis conceived
there is an arrogance about "blaming the customer" if they don't have a good experience - we are here to serve our clients by delivering the best experience for thier customers. Well for commercial work anyway.
