scorsesefan
Looking for a "one man band" wheeled production case to fit 2 led panels (13 inch wide) a few light stands and my fs5 and a couple of lenses. Any suggestions on the low budget end? Thanks
I'm no fan of the Pelican style case because of the bulk (local projects only), but if you like that type of case, there are other brands out there that are virtually identical and not nearly as costly.
OK. Thanks for the tips, guys... Has anyone used this one: https://www.bhphotovideo.com/c/used...FVBoy8uwsy_v-kUCXpIBDsKsMq3m5jXEaAlIwEALw_wcB
A case with wheels still sucks to move once you reach a certain weight/distance needed to travel. I'd get a backpack that can carry as much as you're comfortable with, even if it's just fs5/lenses. Are the LED panels square or rectangular? If they're small enough you could do LEDs/camera in a backpack then a separate case for light stands/tripods which are the same shape. A long, thin case has a pretty small footprint when standing upright too.
