Norbert
You interpret the footage to the widescreen PAR before putting the footage on the timeline.brdplya1 said:I'm still getting black bars on left/right side of picture after movong to timeline and rendering....how do I scale up and remove bars?,,,thanks
And for your previous question, it will take some time. I recently rendered a 13 minute video (almost 20 000 frames) and it took about 4 seconds for Photozoom to process every frame. I devided all frames into groups about 3000-4000 and rendered a group when I felt that I had time to do it. 4 sec x 4000 frames = 16 000 sec = about 4.5 hours. Not that bad. It is still worth it.
Oh yes, I noticed that right after I did my test. Photozoom 2 still has the old S-Spline + faster processing time so I would definitely go for it instead of Photozoom 1.Redshift said:So this leads us to the question: I Photozoom 2 worth it? The answer is yes, if for no other reason than it is faster. If you will look you will see that the original algorithim is there. So you can use the original S-Spline and it should process faster.
