Problems with my DVX's Footage
Hello,
I've had my DVX for a while now (about four months), and I shot some footage the other night in a low-lit area. There is a highlighted square that takes up the upper right fourth of the screen that is showing up on my footage. The square, at times, even seems to extend in a band across the top of the screen and into the left half of the picture. When I alter the color temp settings under the scene file, the square is even more apparent. I've shot in low-lit environments before, and nothing like this has happened. In lit areas, there is no square, but when there isn't much light, it is VERY noticeable. Is there something wrong with my camera? If so, what could it be?
Thank you,
Paul
I used mine in low light for the first time recently & other than a dark picture there was not anything wrong . I have not seen anything like that?? perhaps it may be worth having someone check it out while it is under warenty
