Problems installing hack from Mac. Help?
ian_h
I've Winebottled the latest PTools (3.56), and have 1.32 firmware and the latest seta.ini and seth.ini LPowell settings in the same folder.
Am I right in understanding that after I've loaded the 1.32 firmware, the A-J buttons should have the presets loaded? When I click on them a message comes up "No settings file".
Any ideas what I'm doing wrong?
Thanks, Ian
Ah... solved. Just in case anyone else has Mac problems. You can't create your own folder where you want it on the HD with the ini and bin files. You must put them in the same fodler that Winebottler creates for the .exe file. Buried deep in the Library - open your winebottled app and it will show you the directory structure when you ask it to load firmware.
