Problem with uprez procedure
Sledgeweb
I'm following the sticky:
Shot in 24pa
Captured to 4:3 24p premiere pro project
Exported tiffs (didn't see any option for cropping on export on tiffs)
uprez'd in photozoom to 720x640
Created widescreen 24p project
imported tiff sequence
dragged to timeline
Now I have a square image with the top and bottom correctly cropped off, but with black bars on the sides. I don't have any interpret as widescreen option in my interpret footage dialog. Any suggestions?
Try to change the aspect ratio, instead of using the aspect ratio from file (1.0)
Ulisses
In that drop down box, the only option is 1.0. I don't know why it says this, as it should be .9 (since it's a DV source). I suppose exporting it as TIFF and then doing the photozoom thing... it just became a square PAR?
AH! Got it! For some reason, when I click the drop-down box, nothing drops down. But if I click in that box, and then hit the down arrow, I can scroll through the varios options. So, I set it to widescreen (1.2 PAR), and it looks correct! Wonder why that drop down box isn't working right...
