Problem with Neoscene-converted files
Angus
After having converted my GH1 1080 footage using Neoscene I've noticed that the resulting files invariably show up in FCP7 or Cinema Tools as being "Cineform HD" files whether I select the ProrRes HQ or the CF 422 option in the Neoscene output panel. Should this be? Processing is for pulldown removal and to fix GH1 chroma. Also, if I select CF422 output the file is actually larger than if I convert the same MTS file using ProRes HQ targeted output and yet I have heard that the opposite should be the case.
The reason I am interested is that I cannot get these files - the "ProRes HQ" files converted from Neoscene - to playback smoothly in FCP7. Even with only one video track and four audio - 2 for the camera audio and 2 for music - playback chokes at nearly all transitions - even with everything rendered. Simply adding a title track will provoke the dropped frames warning upon playback. Of course I am adjusting all of the parameters suggested in the warning dialog to get smooth playback but nothing has any effect. Computer is a current 17" MBP with 8GB RAM and using the higher-performance 9600 GT graphics card.
Using logged-and-transferred 720P files poses no playback issue whatsoever so I am beginning to think something is up with my Neoscene-converted 1080 files.
Any ideas?
Thanks,
Angus
