I just discovered a few of my clips have a vertical band on the right side of the frame. The band is static. You can see from the 2 images I've attached. The part affected by the band is more contrasty compared to the rest of the frame. It's like the affected part is half a stop under exposed.
FYI, I'm using a friend's Tamron 17-50mm lens with an ebay 30 dollars Nikon G to Micro 4/3 adapter. The adapter has a internal lever to control the Tamron aperture.
Just guessing and hoping here
, is there a remote chance that the Nikon G adapter is causing the problem or it's a case of camera sensor frying soon?
thanks
thanks
