problem with color balance
masik
I use dvx100a and I got a problem with uncontrol changing of color balance. During shooting it changed few times. I didn't make any changes in options. It changed by itself.
I put short clip on the web and you could see this:
http://www.annyworks.com/pics/color3.html
May be somebody know what is a problem and how could I fix it?
Please, give me any advise.
Thanks,
Alex
Re: problem with color balance
It looks like you have your auto white balance on. I think with the strong backlighting it was making it go nuts. Make sure you turn your AWB off and then set the white balance with a whitecard.
Yep, looks like ATW. If you're going to use ATW (which I would NOT recommend), you should also set ATWLOCK as one of your USER buttons so you can lock it once has a white balance you like. But it's muich easier to manually white balance, and you never have to worry about it changing on you.
[quote author=SirAllen link=board=Events;num=1086560334;start=0#2 date=06/06/04 at 17:15:17] you should also set ATWLOCK as one of your USER buttons so you can lock it once has a white balance you like. [/quote]
thanks
