Print - To - Tape DV
dasonras
Hello. I normally use vegas 5 for exporting my movies, using the print-to-tape method. However, now I am using avid xpress pro, and i am very confused on the best way to export my movie. Basically I want to print it back to DV tape. How do I go about doing this?
Re: Print - To - Tape DV
If you are running on XP Serice Pack 2, you should upgrade to XPress Pro HD (v.5.0) which allows you to ouptut to DV from a 23.976 project type without a Mojo. It will reinsert NORMAL or ADVANCED back over the FireWire.
If running 4.6 of eitehr flavor, then a Mojo is required to output from 23.976p to DV. Or you can always encode as MPEG2 and make a DVD.
Michael
If you're running 4.6 (no mojo) and really need it on tape, export it to AE or similar, add 3:2 pull-down, reimport it into AXP in a 29,97 project and record it to tape.
