Say you have a 24-70mm 2.8 lens and you set it at 50mm and then you also have a 50mm 2.8 prime lens, and both lenses are from the same manufacturer and both have the same wear and tear. Is there any difference when used at 50mm? Why would some prefer the prime?
There's been plenty of situations where I've had the camera set up on a dolly on tracks, and I see the edge of a flag scrunched up against a wall, and I wished I had something between a 20mm and a 24mm, or what have you to tighten up the frame a little.
Zooms can save time and bother, but personally my main reason for preferring prime lenses isn't the sharpness, but the speed and size. Fast zooms that don't breathe much are gigantic in 35mm and even for 2/3" HD those zooms (Panavisions for example) are very large and heavy.
In the end, temptation to use misc. focal lengths on a zoom should be a will power exercise any DP should be able to win. I guess my real point is that I work with a small set of primes per scene. Usually I like to use either just wides or just telephoto depending on story and mood."We didn't use a lot of lenses to shoot the movie. The 40mm was our long lens; sometimes, when we just couldn't get the shots that we wanted with the 40mm, we used the 50mm, and once or twice the 75mm. In general, though, the 40mm was our longest lens and the 21mm was our widest. The 27mm was our normal lens, and we also used the 35mm. In my opinion, when you start combining a lot of lenses, the look becomes a bit too rococo or baroque-- there are too many different variations, and you lose something intangible. We wanted to keep the look of the film consistent." -Emmanuel Lubezki, ASC, AMC (regarding Sleepy Hollow)
"The entire picture was photographed with one lens, a 28mm. We used it for every shot, although it did cause something of a sound problem with camera noise when we would move in for the close-ups. Bogdanovich wouldn't even allow a zoom lens on the set. He detests the zooms, even if they are just used to follow someone. Orson Welles had told him that a zoom creates artificial movement, and technically, he's correct. A zoom shot is merely a magnification of an object. It doesn't at all give you the same perspective that you'd get, for example, if you dollied through a doorway. However, there were many times when it was necessary to move the camera a couple of feet to tighten up the composition on a shot. Using the zoom would have literally saved days on this picture, but Peter insisted on laying dolly track and dollying that couple of feet. He has his integrity-- which is very important to him-- and you have to respect him for it."
- Robert Surtees, ASC
Robert Surtees, ASC discussing lenses on the film "The Last Picture Show" (which is an AMAZING film in regards to the cinematography)
So let me ask you this.... Considering it's a perfect world, what focal lengths would you include in a complete set of primes?
But later I found out that I could've got the exact same lens except it was Tamron for $900 cheaper than the Nikon.
