Peter C.
I finished filming an outdoor event this weekend which I used my Sony A74. On the whole did a good job but I had a few things I struggled with.
The first was using the presets on the dial. Sony allows you store setups frequently used. I had one set to 60p, 30p and 24p. The frustrating part was every time you change the dial all the setting change even the ones you don't want. For example the white balance was set to indoors, to change it you have set it then go deep into the menu and save the preset then do the same for each preset, then I found being in bright light wanted to change the aperture to f8. But for every change you need to record it to all the presets otherwise when you switch between them it won't match.
Seemed like it might have been simpler leave it in manual mode and not use the presets.
The second issue was just dealing with exposure. The event had a large tent and people were both in and out of it. So every time moved between them exposure would need to be changed 4 stops. Despite liking to have full manual control it might again been smoother and quicker using auto exposure. I missed a few shots because I was fiddling constantly back and forth with the exposure. The other reason I was hesitant using auto was that I was filming in SLOG3. Didn't want to fool with that in the middle of an event not knowing what it would do.
