Premiere Pro outputs discolights
Martin.G
So i have this weird bug.
In a test render, everything looks great.
In the full render however, everything goes through the window.
I have tried to take on and off effects and the only effect having a result is the Lens Distortion plug-in from Adobe. My next try will be to remove the lens distort that repairs the wide angle distortion, and do a full render.
The plugins in the edit is:
RBG Curves
Lens Distortion
Warp Stabilizer (on the crane shots)
Fast color corrector (adjustment layer)
Magic Bullet (adjustment layer)
Full render with disco light bug:
https://www.youtube.com/watch?v=o_NdS43JK4c&feature=youtu.be
Test render without any issues:
https://www.youtube.com/watch?v=B2eSIEY7lLw&feature=youtu.be
The same part in the test render has 100% the same settings enabled. No effects was disabled for the test render. And take a look at the night shots in the full edit. Not a single disco light is visible in that part. So weird. Has anyone else been through similar bugs before? Any possible solutions?
Edit:
So i gave up and reverted to an earlier version of the project. I copy pasted the grade from the borked project and laid it on top of the older version. Rendering is much faster and more agile now. Probably something got twisted inside the PP project files, eating up all of my computer resources and bugging up.
Edit 2:
Discolights still visible. However, they are now gone from the office part of the cabin as well.
Edit 3:
Its Magic Bullet Looks causing the issue.
Appearently its not enough to "hide" the layer which encompasses Looks. I have to remove it alltogether from the project before things get normalized. Doing the grade in Speedgrade now. I dont know this program so things go not as fast now.
Looks like some effect is malfuntioning on some frames, maybe a ram or vram issue? What effect seems to be missing on the flashing frames? Looks like some color correction so not stabilizer... See if you can match the look of a bad frame by disabling one effect.
I found it to be Magic Bullet and Colorista, and i had to completely remove the effects. Just shutting them off did not yield any results. The discolights appear as soon as colorista or magic bullet is applied to a clip on the timeline.
Got a support ticket going now, will keep you posted.
